Is this right?
Is this right?
DSC01573 (Small).JPG (87.37 KiB) Viewed 880 times
Installed my new windshield glass, and I have this gap. What goes there?
My truck came without glass, so I have no reference, Pics would be great.
scott k
Re: Is this right?
Post by scott k »
Yep there is a small rectangular foam strip that goes there. On the top steel hinge part that is screwed to the frame there should be a tab at the ends for clamping the foam.
Re: Is this right?
scott k wrote:Yep there is a small rectangular foam strip that goes there. On the top steel hinge part that is screwed to the frame there should be a tab at the ends for clamping the foam.
Thanks, I wondered what those tabs were for. Now to find the little squares.
Sure could use a pic if anyone has one of this.
Thanks again,
