Civilian Oil Pump
delta31
Civilian Oil Pump
Post by delta31 »
We will be installing a new civilian oil pump to match our new civilian distributor.
Rock Auto shows 2 oil pumps, a standard one and one with a right hand gear. I'm assuming the dodge 230 in an m37 would work with the standard pump.
Is that correct? Thanks
Re: Civilian Oil Pump
Sorry for the delay Delta,
Can you post a couple of photos so we can see what you're describing?
