Which OD?
Which OD?
I was looking at exterior paint colors and wondered which of the OD's is correct for my '53 M37. I'm looking to buy some Gillespie Coatings paint.
Jeff in north Texas
Nickathome
Paint...
Go with Gillespie. I tried Aervoe from rattle cans and it seems to fade fairly quickly. It doesn't seem to hold tight either and chips easily.
BTW - 24087 has a slight brown look to it, so you should be good to go.
I use the aerovoe in my spray gun with a little lacqure thinner, and use the rattle cans for touch up and seems fine it does wear through on high contact areas like the pedals and entry point on the jeep but sems fine other then that and I think any paint will wear in these areas, our vehicles are all motor pool drivers
anyone wants a pic of the m37 after I sprayed it let me know
I Wanna See!
Hey Tom,
Did you paint those front fenders, I wouldn't mind seeing 'em on your truck.
BTW, How's your Dad?
Regards,
Regards,
