Body Bolt Question
JoeM37B1
Body Bolt Question
Post by JoeM37B1 »
I'm re-assembling an M37B1 and need to know if there's a source for bolts for attaching the front/rear fenders, splash shields, etc., instead of trying to salvage the corroded take off bolts. Or, do y'all just use common hardware store bolts? Thanks for any suggestions.
Re: Body Bolt Question
Buy bags of fine and coarse thread Grade 8 at your local Fastenal Store, plus washers and nuts. Then paint them when all done. hc
RMS
Post by RMS »
and if your picky some military vendors have the clover washers in stock
RMS wrote:and if your picky some military vendors have the clover washers in stock
Tom at Snake River used to have a great assortment ot the crush washers? They come with the iridium coating.
Charles at M-Series Rebuild sells cans of used bolts that could be blasted clean then painted.
