Antenna Base ID
Explorer0863
Antenna Base ID
Post by Explorer0863 »
Hello everyone. Any of you recognize this military antenna base? I am considering to buy it for my M37, but the owner doesn’t know what it’s off.
Tony
USAF SP/SF Vet
1963 Dodge M37B1
1955 Dodge Power Wagon
Re: Antenna Base ID
It is NOT the AB243 triangular mount that is common on the M37. Never seen that mount in my travels.
Murf
Re: Antenna Base ID
Post by Murf »
That lip on the backside will prevent it from mounting correctly (flush) against the bed side.
Re: Antenna Base ID
Agreed, not for the G-741, maybe earlier mount, but not M-37 I guess you could make fit, maybe?
Re: Antenna Base ID
It holds an AB-15 antenna base. I had one one my M151. It fit the rear corner very nicely. Would need some modification to work on the M37 as stated above.
