Page 8 of 12
Re: Grandpa’s M37
Posted: Sat Feb 12, 2022 10:58 am
by greeno
Pretty detailed….but very, very small.
- 553D7B11-A531-4862-8760-BB3F551BA891.jpeg (78.72 KiB) Viewed 2763 times
Re: Grandpa’s M37
Posted: Mon Feb 14, 2022 5:18 am
by UZIS9MM
You're going to need some hella small tools to work on that beast!
Re: Grandpa’s M37
Posted: Fri Feb 18, 2022 5:04 pm
by greeno
Ish. Not for me!
- 8AAECA10-398F-4895-8062-83690C1C7D0D.jpeg (73.5 KiB) Viewed 2708 times
Re: Grandpa’s M37
Posted: Tue Mar 22, 2022 4:12 am
by greeno
Finally got a bunch of parts back from the blasters. Another trip to MWM is in order too. But I did drive it up and down the street on Sunday waving to the neighbors!
- 1F22E35C-D503-4DA9-9DF6-8C544D0919A2.jpeg (96.94 KiB) Viewed 2657 times
Re: Grandpa’s M37
Posted: Tue Mar 22, 2022 11:14 am
by John Mc
Looking GOOD!
Re: Grandpa’s M37
Posted: Tue Mar 22, 2022 10:07 pm
Awesome work Greeno!
Re: Grandpa’s M37
Posted: Fri Apr 01, 2022 10:43 am
by greeno
So, I, uh, was cleaning up the shop and found the bench bleeding instructions for the mc….which I forgot to do!
Tear it out and bench bleed? Everything is hooked up.
Re: Grandpa’s M37
Posted: Fri Apr 01, 2022 9:00 pm
by PoW
I never bench bleed a MC.
Get a pressure bleeder and do it in the truck.
You only have to do it once that way, and you can do it without any helper.
Re: Grandpa’s M37
Posted: Sun Apr 03, 2022 5:13 am
by NAM VET
I made this up to easily pressurize my MC, and bleed my brakes by myself. Be sure to turn off the vent valve, or you will pump brake fluid out onto the garage floor. Bought from Jegs or Summit a half inch NPT fitting and then from same a smaller NPT with a nipple, and a Motive pressure bleeder which I have used before on other cars. Let me try to post a pic.... Hal.
[/img]
Re: Grandpa’s M37
Posted: Sun Apr 03, 2022 5:14 am
by NAM VET
ok try again.
Re: Grandpa’s M37
Posted: Sun Apr 03, 2022 1:50 pm
by m-37Bruce
Is it hand pumped Hal?
Re: Grandpa’s M37
Posted: Sun Apr 03, 2022 2:49 pm
by NAM VET
yeah, a tank with with a pump handle, with a pressure gage, and a plastic hose you can connect to whatever fitting you want. Takes a little planning to get what you need, but works slick as a whistle. Jegs or Summit has what you need. Hal
Re: Grandpa’s M37
Posted: Sun Apr 03, 2022 10:04 pm
Same as Hal-Motive bleeder with a fabbed MC plug.
Re: Grandpa’s M37
Posted: Mon Apr 04, 2022 8:08 am
by greeno
Thanks guys. Wasn’t sure if there was any magic in bleeding on the bench. Doesn’t sound like it, just might take a little more time to properly bleed the system.
Re: Grandpa’s M37
Posted: Mon Apr 18, 2022 12:27 pm
by greeno
Speedo bounces a lot. Lube the inner cable?
https://youtu.be/r3K840r1G0Y
