Original Wood used for the Troop Seats
Posted: Thu Jul 23, 2020 6:36 am
by LegionPiper
Hi folks,
I tried several searches on this subject with no luck.
What was the original Wood used for the Troop Seats ?
I've seen folks using Mahogany and White Oak and since they are normally painted, I'm guessing it's not a big deal ?
However for the books, was it Pine ???
Re: Original Wood used for the Troop Seats
Posted: Thu Jul 23, 2020 7:19 am
by Elwood
Likely not a softwood like pine. I used a hardwood (oak), but ash or similar would work, too. I've not had good luck with maple, as it tends to warp.
Posted: Thu Jul 23, 2020 12:44 pm
by NAM VET
I used ash, inexpensive, and plenty strong. I rounded off the edges a bit, to avoid cuts. It was easy when I use the old boards for a pattern to drill the holes. New carriage nuts, stainless nuts. Painted mine black, hc
Posted: Fri Jul 24, 2020 4:23 am
by Sal
I believe I read over on Steel Soldier a while back that oak was used. I used Red Oak on mine only because I like the look of it .
- DSC02357n.jpg (176.83 KiB) Viewed 2538 times
Posted: Fri Jul 24, 2020 11:11 am
by NAM VET
What an immaculate truck! I have spent two days de-mudding mine from the winch out episode of earlier this week. Hc
Posted: Fri Jul 24, 2020 2:27 pm
by John Mc
I don't know what was originally used, but White Oak would be an excellent choice. It's strong and rot-resistant, even when left unfinished. It will hold up significantly longer out in the weather than Red Oak or Ash.
Posted: Sat Jul 25, 2020 4:42 am
by Murf
It's definitely an oak. I have my original rails and am going to replace them. I cut a piece and they still, without a doubt, smell and look like oak.
Posted: Sun Jul 26, 2020 11:19 pm
I have an NOS box of bed bow wood in the basement and can take a look, assuming the other wood was of the same material.
More to follow,
Posted: Tue Jul 28, 2020 8:47 pm
Hi All,
I dug into the box today-it is likely white ash, very strong but flexible.
Posted: Wed Jul 29, 2020 7:16 am
by John Mc
Ash is a great choice for something that needs to be bent. However, unless it's finished with some sort of protective coating, it's not as weather resistant as some other species.
Posted: Mon Aug 10, 2020 7:51 am
by just me
One of the parts manuals specs it as Red Oak. I used Ash as I couldn't get hickory.
Posted: Tue Aug 11, 2020 8:48 pm
Good to know, Justme-I'm no expert on wood but my box is certainly not red oak.
