Floor Board Seals?
Floor Board Seals?
We tried to re-assemble the floor boards last night - yikes - you'd guess that they came off a different truck. I imagine that between all the blasting, sealing, and painting, they wandered off be "true" dimensionally. Given the twisting, we could see air underneath the joints. We bought some small closed cell window seal from the Home Depot and installed it near the edge of the openings. It sealed the cracks all the way around versus the sealant that we had seen on the original. Anyone else notice this? Or are we just being too picky?
Not Going There
I'd be careful what you use to seal the floor, originally it was okum or hemp with some tar type stuff, it held water between the joints. One side sticky foam is another bad choice
A better choice would be butyl, similar to what is used on the windscreen and windows, it stays elastic forever almost, Charles might have a better idea?
- milstencil
- CPL
I used 1" x1/8"x25' rolls of rubber from http://www.unirubber.com/index.htm
which I cut and glue with 3M weather stripping cement to the panels.
They also have the little rubber bumpers for the first aid kit holes.
Regards,
Rick
Regards,
Rick
