Marine Diesel fuel pump - works great for gasoline engines, too. Walbro #6803. Used for 2 hours. Minor cosmetic damage, but works perfectly. I have one on my truck and it has made a world of difference.
Note, this is a *7 PSI* pump - you will need a pressure reducer to use with an M37.
24V electric fuel pump
