"A Good Driver" sticker.
DSC01191 (Small).JPG (121.96 KiB) Viewed 1889 times
Was the A good Driver sticker installed on all years? Was there a "proper" place to put it? I found one on my drivers door (under several layers of paint). The replacement ones have a 1973 date on them, were they put on at a later date?
I have seen pics of them on the dash of 715's.
DSC01190 (Small).JPG (107.44 KiB) Viewed 1889 times
milstencil
Re: "A Good Driver" sticker.
Post by milstencil »
Here ya go:
Rick
Thanks milstencil, is there an earlier version? mine is yellow, I have seen some that were white too. A '62 decal is still 8 years younger than my truck.
Trying to determine if this was a later add on.
milstencil
The "62" version was used up until 1972 when it was replaced with this one:
Notice it says older version will be used until stocks are depleted.
The white ones were used on armored vehicles.
sturmtyger380
Post by sturmtyger380 »
Mine was on the inside drivers door in the upper right corner. In fact it looked like there were three there one pasted on top of the one before.
sturmtyger380 wrote:Mine was on the inside drivers door in the upper right corner. In fact it looked like there were three there one pasted on top of the one before.
That is where mine is. I have seen pics of them on the left side of the door, and on the dash(715, might not count).
Bob,
Mine's in approximately the same spot as yours, and it appears original and unmolested.
It's my understanding the placement of the stickers was a unit commanders decision. Which means in Alpha company they were on the drivers door left hand side and in Bravo company they were placed drivers door right hand side etc.
Got a replacement sticker from Milstencil. Thanks!
