window parts
vinnytruck
window parts
Post by vinnytruck »
Does anyone have a extra "T" screw that holds the window up to get air into the cabin area?
vinnytruck
Re: window parts
That T-bolt "shouldn't" be removable. It is supposed to have an upset end to prevent removal. So, you usually need to replace the 4 piece prop assembly. Especially if it was forced out of the leaves and ruined the threads. I have no spares at this time. But I'm sure someone here does. If not, they aren't expensive from the usual sources.
vinnytruck
Re: window parts
thanks JM, I didnt know that. Should I just put a smaller bolt/nut thru, or maybe someone has one for sale. thanks again friend VT
vinnytruck
