1954 Cdn M152, M37, M43 Parts For Sale
thmpr
Post by thmpr »
All parts in Phoenix, Arizona 85018 Prefer local pickup.
Many Canadian M152, M37, M43 parts available. 30,000 original mile M152 command truck is having its entire drivetrain swapped out and switching to 12 volt electrics. Turning vehicle into a fully equipped, bug-out, overland expedition truck.
What do you need? Let's talk. All prices are or best offer. Bundle!
CANNOT BELIEVE I STILL HAVE THIS RUNNING ENGINE! I thought everyone desired the larger 251 engine.
Running Canadian 251 engine, includes 24 volt generator/alternater, 24 volt regulator, 24 volt generator to regulator cable, bell housing, clutch and throwout bearing, 4 speed transmission, 24 volt starter, and rare cold start dash pump. Needs fuel pump and carb rebuild. $1,300.00 Recently pulled from truck, ready to be lifted into your trailer or pickup bed. Have video of it running prior to pull.
Front and rear leaf spring lower shock mounts with shocks $50.00 for all four.
Set of 4 guages (no oil pressure) and 2 gauge lights $50.00
Ceiling ventilator ducts (2) $100.00
Many more pieces, parts, misc. 24 volt bulbs
Contact Glenn at 602-956-6695
Phoenix, AZ 85018
Re: 1954 Cdn M152, M37, M43 Parts For Sale
I could use all the generator, starter, regulator stuff. If you have a PTO. I'm in Phx, Also.
thmpr
Post by thmpr »
Bump
choppa
Post by choppa »
glen.
may be interested in the 251 engine..
just texted you. looking for details on engine condition. I see its a running motor.
does it smoke or any other issues at all? Oil pressure? Do you know compression?
thank you
OH.. My only reason for not contacting before this was concerns on distance. I sure don't want to drive there from Oklahoma so would be looking for suggestions on shipping or someone willing to haul. thank you!
you can contact me off line if you want, or to my text?
Or send pics and condition to wc57doggieboy@yahoo.com
