Distributor parts
cweber2
Distributor parts
Post by cweber2 »
In need of the snap ring that holds the mechanical advance in place . And idea where I can get open ??
Re: Distributor parts
cweber2,
If it's the ring I think it is (ORD part number 5346767), here are the specs for it, with the NSN at the bottom. There's a cross reference for this part on
https://aerobasegroup.com/part-number/5 ... 0-200-7415
Casehardening Indicator: Not casehardened
Cross-sectional Shape Style: Round
Material: Steel,qq-w470,class a or b
Outside Diameter: 0.312 inches nominal
Material Diameter: 0.031 inches nominal
Ring Style: Double leg offset
Usage Design: External
Federal Supply Class (FSC): Fastening Devices
National Stock Number (NSN): 5325-00-200-7415
Hope this helps.
Kaegi
Post by Kaegi »
I need a dist part also. the washer that goes inbetween the retaining hub on the shaft and the bottom of the distributor. so if you find anyone parting one out let me know. thnaks
You could form that out of a guitar string or piano wire if you can't find one.
Or substitute an external snap ring (aka "retaining ring"). Easier to source, and easier to remove and install.
JBizal
Post by JBizal »
Midwest Military has these parts in stock.
John
