Distribuitor bushing replacement?
cweber2
Post by cweber2 »
Is there a "how to" for replacing the bushings in the Distribuitor on a 37 ?
point
Re: Distribuitor bushing replacement?
Post by point »
Can you even find a bushing? I need one.
RMS
Post by RMS »
why has the bush on that spare dizzy of mine pooched too ?
You could just make your own bushings. But they are one place, like the water pump, where fit and finish is critical. I am just about to pick up a spare dist to do that job on. Don't want my still operable one out and have the truck down.
My plan is to grind the shaft if needed and then make bushings to fit. I'll do whatever rehab to the advance mechanism as needed.
point
Post by point »
A whole lot better than my old one but still a tad of play
cweber2
Post by cweber2 »
Got bushings from vintage! Press in but have to ream to .501" !!!! Too tight if u don't !
