24 volt conderser
richard 775472
24 volt conderser
Post by richard 775472 »
Hi all,
The other I was in search mode on Midwest Jeep Willys parts site and I found out that there was a 24 volt condenser for sale, so I went back to the shop and look for that condenser on my m37, I didn't find one,,Question; do I need one for M37 1953, Canadian version? :?:
RMS
Re: 24 volt conderser
Post by RMS »
should be located @ 12 O'clock under the distributor cap some times you will find two 12v condensers crammed in there.
richard 775472
Well, I did look there and other place, but no luck.
RMS
Post by RMS »
if your truck is on points you need a condenser. if you have a petronics kit a condenser is not required
richard 775472
because I don't know to much about mechanic, my friend is a mechanic and will be here Monday .
for now all I can say is that the motor start and run good :roll:
richard 775472
Well well well, went you right (should be located @ 12 O'clock under the distributor cap some times you will find two 12v condensers crammed in there.) I didn't understood underneath the cover it self, so that wy I couldn't find anything the thing it self--INSIDE was were to look, that's all the deference for me to translate in french. But the end result is that , I'm pretty sur to find them inside when I remove the cap tomorrow.
Sal
Post by Sal »
Richard.It should look something like this once you take the Distributor cap off.
TESTING COIL1.jpg (116.97 KiB) Viewed 1771 times
Sal
:mrgreen:
1954 M37 WO/W
1969 M101A1
richard 775472
thanks ,,it was in there,,,,,,,,,,,,,,,,,,,,,,,
any suggestion to where I could find the front end bumper dimention (the full lent - not the winch one)
mind is missing his, this is the last thing left to do and then, = provincial inspection.
Richard,
The non-winch bumper is 5'3" (63") long from end to end and 7.5 inches tall.
