I am trying to adjust the timing on my truck but my mark is way to the left of the pointer. What would cause this. Engine has been completely redone with petronix ign installed. Could something be done wrong?
Thnx
Timing help
Timing help
Gerry
53 M37
53 M37
- Cav Trooper
- SGT
Re: Timing help
That was the problem with mine. When I got it, the timing was so far advanced that I couldn't get it close. Removed the oil pump and reinstalled correctly, problem solved.
HHT 2nd ACR
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
1967/68
Chu-Lai, S. VietNam
1969
Cav Trooper
Re: Timing help
Update.
After trying two more times I tried rotating oil pump one extra spline and the timing was right on. Thanks all for the input. Frustrating it didnt work how manual describes.
Gerry
53 M37
53 M37
Re: Timing help
some times the marks dont line up on the pump to compensate for the twist of the gear.
good to hear you got it sorted. is she breathing fire ?
Re: Timing help
Yes she runs. I think I need to Just need to fine tune carb. Idles slightly rough. Had to work today so no time for test drive till tomorrow.
Gerry
53 M37
53 M37
