gaskets on rear axle importance?
billy
Post by billy »
It looks like I lost the gaskets.Think I can use some permatex the right stuff?
this is all i got
Murf
Re: gaskets on rear axle importance?
Post by Murf »
The gaskets fill in the irregularities between the two surfaces. They are the thin paper-ish kind. permatex might be squeezed out too much. You can get gasket material at any auto parts store. Use the flange on the left to trace the pattern. For the holes I used a spent 9mm shell casing to punch them out.
pwrwagonfire
Post by pwrwagonfire »
FWIW, I have tried both the gaskets and permatex.
I thought that permatex got a much better seal. Hey, I say go for it, you can always change it pretty easily if you need to.
-T
Kaegi
Post by Kaegi »
either way will work. if you want the gaskets the part number is 4390 at napa or elsewhere. I think that's a felpro number. less than 2 bucks each
Anaerobic gasket maker works great, we have not used a gasket in years. Materials such as the right stuff are a nightmare to clean off at the next disassembly; anaerobic comes off easily.
skinnedknuckles
Post by skinnedknuckles »
I agree with Charles on the use of anaerobic sealer, I use it alot on on the big trucks and the heavy equipment that I maintain here at my shop. The nice things about stuff is that you don't have to be in a rush to assemble, it will sit there just fine for a while ( just keep dirt off it ) , it works great on flanges and housings that have good even clamping pressure, it has some flexibility and it sets up almost immediately and it cleans off easily with a razor blade once dry.
Paul
Paul in Janesville, Wisconsin
1953 m37 parts truck
MVPA and MVPG member
