WTB - bodywork seals
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
G'day all..
I am after a cowl vent seal (most imprtant part of request), the door and window rubbers plus the runners that go inside the doors as my windows have become very difficult to wind up.
Regards - MM :-)
Trained Monkey on Guard
dodgem37@netspace.net.au
G'day, Shagger!
The usual bandits may (or may not) have the cowl vent seal you're after.
The liners for the window tracks should be available from your nearest auto glass shop in "cut-to-fit" lengths. If not, Memphis Equipment Co. lists the complete channels in their catalog (part # 7374830, 2 required for each door).
JBizal
Seal
Post by JBizal »
I have the cowl vent seal in stock. I just had them reproduced.
www.midwestmil.com
John
My windows cranked with difficulty too until I hit the scissor tracks and their pivot points with a wire wheel, then sprayed on some white lithium grease-smooth as silk now!
Monkey Man
Site Admin
Site Admin
Thanks Lifer, Gary and John, I'll check them out as far as the winder mech and local rubber suppliers go and John, could you drop me a line with a price including freight to Launceston Tasmania Australia 7250.
Thanks & Take Care
Best Regards - MM ;-)
