Fording Kit Intake Pipe Wanted
carolinamv
Post by carolinamv »
Im looking for the intake pipe for the fording kit for the M37. If you have a old or new one, or are thinking of pulling one off your truck I will sure pay up. Name a realistic price and Ill buy it righty away. that's about the only piece I need to complete the truck so I will sure pay up!
-Jay
MVPA#31295
http://www.mvcconline.org
3/3 CAV HWB
isaac_alaska
Re: Fording Kit Intake Pipe Wanted
Post by isaac_alaska »
Surprised no one is remaking this yet... The rest of the parts seem fairly common. Maybe the rest of the parts were commonly left installed and only the intake pipe was removed and stored after fording?
Isaac
Fairbanks, AK
Civilian WM300 on DC3 tires
'52 M37 on 11x16 Michelin
Photo Gallery
carolinamv
I agree,
Im all in if I can find one.
-Jay
MVPA#31295
3/3 CAV HWB
M60TC
Post by M60TC »
Has anyone made a Blue-Print Paper Design of the Parts???? It would be easy to build if you have the specs.
Don
carolinamv
Id buy a repro. It doesn't make much sense no one has them or even a repro when they repro make fording tail pipes.
-Jay
MVPA#31295
3/3 CAV HWB
DCook
Post by DCook »
Don't forget that I am waiting in the same line for the intake side for my truck. I need the mounting bracket, and intake pipe. I think John at MWM has the hose.
Help Anybody!!
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
isaac_alaska
I'm more than willing to draw a 3d model if someone wants to take photos and measurements. Then it would simply be a matter of money to take the blueprints to a local metal fab shop. The topper might be complicated
Isaac
Fairbanks, AK
Photo Gallery
rickv100
Post by rickv100 »
Is there an NSN for the parts? The pipe can be mandel bent anf the brackets fabricated.
Rick
carolinamv
We have a member looking into have a copy made, or copies.
-Jay
MVPA#31295
3/3 CAV HWB
isaac_alaska
I'm sure this has been answered before but I can't find it now... My truck came with the fording shroud around the air filter. In normal operation, is the truck meant to be run with the shroud installed with the top secured, and just the intake pipe removed? I remember reading that having the full intake kit with pipe installed will choke the motor, but I don't remember specifics on the shroud installed or not.
Isaac
Fairbanks, AK
Photo Gallery
carolinamv
You would think since your limiting the air intake from the stock screen that goes all the way around the air filter intake to putting on the fording shroud with a small open hole you would be reducing air flow. Im sure someone can explain it better , that's my thought though.
In normal operation you shouldn't have a fording kit shroud on it since your not fording the truck.
-Jay
MVPA#31295
3/3 CAV HWB
outsider
Post by outsider »
Put the cover under the seat in the cab. Your engine will appreciate it.
Steve
isaac_alaska
Cover, do you mean the whole shroud that covers the air filter, or just the "lid" of the shroud? It's all taken off right now so it's real easy to do either one.
Isaac
Fairbanks, AK
Photo Gallery
outsider
Post by outsider »
Just the lid. That will let the engine breath like normal, and if you are at a show you can always quick put it on.
Steve
