Fuel sending unit
Dutch
Fuel sending unit
Post by Dutch »
What the best place to get a new sending unit? I have heard that some people will send you a m151 sending unit, will that work without any problems?
Re: Fuel sending unit
If you get one with a hollow blow molded plastic float, replace the float with shellac coated cork or something before you install it. That blow molded thing won't last. It will hole itself and sink.
A mutt float will work OK.
DG
DCook
Post by DCook »
I just got one from John at Midwest Military. I also replaced my gauge at the same time. If the sending unit and the gauge are not made to work together, if you get a reading, it may not be at all correct. This set I got from John is working fine. The new senders have a rubber boot type plug in for the sender wire, so your truck wiring may need a different end installed.
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
You make a Douglas to Packard pigtail. Mine came with one.
Dutch
Post by Dutch »
What kind of float did the one you got from Midwest have? Plastic? Cork?
DCook
Post by DCook »
The MWM sending unit had a plastic float. It has only been in fuel, doing its thing, for a couple of weeks now. So far, no problems with it.
MVPA Member #23780
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
They are, as near as I can tell, all from the same source unless they are NOS. Newstar is the reproducer. The stuff seems 50-50. I've had two major problems with the sender I bought a few months ago. (Dont remember if it was MWM or VPW.) The float ripped it self open from whatever reason where it was held on the wire arm. And a month later it quit again. This time a cold solder joint (very poorly engineered) that required drilling thr housing open to access to repair.
Disappointing, but expected from hecho in India, China or Indonesia parts.
Dutch
Post by Dutch »
Thanks for the info guys! I will see what I can come up with!
