List of M37 parts for sale some on Ebay
DAP
Post by DAP »
I have M37 parts that are extra and I don't think I will ever need them. Any parts starting with an E are on sale on EBay for the next 9-10 days. See http://www.ebay.com/itm/281686754706?ss ... 1555.l2649
for my first EBay auction and then look at the rest (18 auctions in all).
I also have pictures out at:
Go to my picture gallery to see pictures of these parts http://g741.org/photogallery/main.php?g2_itemId=5939
I live 25 min. south of I-485 south of Charlotte, NC about 3 miles north from SC border. I listed what I want for each piece but make me a reasonable offer on any or all of it. You will need to come get the parts. Parts are used take-offs sold as is unless stated otherwise (SB=sand blasted to bare metal, B=painted black, OD=painted Olive Drab, @=each).
Revised list of parts for sale updated 9 June
1962 M37B1
1962 M116A1 Generator trailer
1964 M101A1 3/4 ton trailer
Re: List of M37 parts for sale some on Ebay
I could sure use the steering box if you could somehow ship it to Arizona.
DAP
Post by DAP »
The steering box has the steering wheel shaft and drag link attached to it and is very bulky and greasy. I don't know any way of wrapping it and sending it via a shipper that would not be terribly expensive. If you had a friend coming thru NC on the way to you maybe you could work out a hand carry?
1962 M37B1
Put in a garbage bag and then in a box a set of golf clubs came in has worked in the past for me.
DAP
M37 frame & parts, M101 trailer, disc brakes
Post by DAP »
Just posted my M37 frame, engine, and parts on EBay SOLD
Then I just posted my good extra M101 trailer for sale on EBay. It also has M37 disc brake and hydraulic hitch if the winning bid is high enough. SOLD
1962 M37B1
So I guess you don't want to do anything with the steering gear? (Not much to pick from in the way of parts in this neck of the woods.)
DAP
Post by DAP »
I checked with local Fed Ex and UPS and they said no I would have to do serious disassembly to make smaller and then box and seal it enough to guarantee absolutely no oil/grease leakage. With AML I am very limited in what I can do right now.
1962 M37B1
Oddball-CmK
Post by Oddball-CmK »
Just me, are you looking for just the steering box, or the whole steering assembly? If DAP is unable to ship to you I might be able to help. The only component I don't have that I'm aware of is the worm gear... I sold that separately.
Regards,
Cordell
I was wanting a complete usable box. Don't know what will need to be replaced in my existing box, but it is dying. Wanted to be able to keep the truck drivable as much as possible. I have no place that I can just let it sit dead.
Gunter635
Post by Gunter635 »
I have shipped things via Greyhound. Slow but a little cheaper than the normal carriers. I shipped a 5 speed trans that way. No problems. You might want to give that a try.
"Regiments broke at first fire". 1952 M38A1. 1958 M37B1
Charles at M-Series sent me a complete steering gear w/ shaft a few years back-I don't recall shipping being difficult or expensive (but again, that was a few years ago).
DAP
Post by DAP »
I edited the original list as some stuff has sold. I am getting ready to put my Pioneer Tool trailer up for sale in the next few weeks. I will post here before I sell on EBay. I also will be selling my M101 trailer. I have not decided what a fair price will be for the stuff yet so don't ask.
1962 M37B1
DAP
Post by DAP »
New list of parts on EBay
E-Battery box and top (no inner tray) - SB/B $85
E-Blackout mount $10
E-Bumper mount set $25
E-Differential pumpkin $50
E-Door access panels 2each SB/B $5
E-Door RH black $100
E-Engine Hood painted SB/ Blue & Black Imron $100
E-Fender green gloss OD RH 100
E-Floor shifter covers 2 each SB/B $10
E-Frame cross members that gas tank mounts to - B $10
E-Front fender supports SB/B $10
E-Fuel filler neck and cover SB/B $25
E-Gas pedal SB/B $10
E-Glove Box door SB/B $10
E-Headlight brush guards LH & RH SB/ B $40
E-Headlight mount $10
E-Headlight wire loom cover 2each SB/B $10
E-Hood holding hooks 2each SB/B $10
E-Hood latch SB/B $5
E-Instrument panel SB/B $10
E-LH tail light mount SB/B $10
E-M43 step hinges SB/B $5
Emergency brake lever and rod SB/B $15
E-Mirror mount SB/B $5
E-Outer main windshield frame stripped, slightly bent- easy to straighten SB/ B $75
E-Radiator brush guard center top – SB/B $20
E-Radiator brush guard center top & bottom – SB/B $50
E-Radiator quarter panels LH & RH $25
E-Rear Bumperettes LH & RH SB/ B $50
E-RH turn signal mount SB/B $25
E-Rotating Engine stand $25
E-Running Board mounts LH & RH SB/ B $40
E-Shock absorber SB $5
E-Shock mounts and spring arrestors SB/B $10
E-Short drive shaft complete transmission to transfer case 3@ $10@
E-Short drive shaft transmission to transfer case female end only 1@ $10@
E-Steering gear box and steering shaft with arm linkage $50
E-steering gear column parts and guards $10
E-Tailgate hinge set 2@ SB/B $20
E-Tie rod with ends SB/B $25
E-Transfer case $50
E-Transmission $25
E-Transmission cross member $5
E-Windshield pivot set SB/B $20
Pioneer Tool Trailer $2700
1962 M37B1
refit1701
Post by refit1701 »
RIP, DAP. We will miss you.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
