good 230 engine for sale NH
justindearb
Post by justindearb »
Hello I have a good 230 engine that I pulled out of my m37 less than a year ago because I put in a 251 instead, this engine runs excellent has a freshly refinished flywheel clutch and pressure and ring gear all perfect comes with bell housing newer water pump I did a 3 angle valve job about 6000 miles ago ran lead substitute comes with manifolds everything in pic minus the 12v distributer, std bore, the only thing I would do is is tappit gaskets clean paint and install
$650 call Justin 1-603-491-9593 or email at justindearb@yahoo.com
IMG_0132 (640x480).jpg (191.92 KiB) Viewed 1343 times
DCook
Re: good 230 engine for sale NH
Post by DCook »
Justin,
Where is this engine?
MVPA Member #23780
1951 M37 W/W, & Field Radio
1958 Navy CJ3B
1967 M725 Ambulance
1987 M101A2 Trailer
xm708
Post by xm708 »
Contoocook NH so says his craigslist ad.... Right Justin ??
justindearb
Yes that's correct I'm in contoocook NH 10 minutes from concord
justindearb
sold thank you!
