Jeep Wheel Question!
Tim Powell
Post by Tim Powell »
Hello Crew.
I bought a CJ2A a while back. The tires and even the rims are in very poor condition.
On one of my trips to Nebraska I found a set of wheels and non-directional tires (7:00x16) for a reasonable price.
A Friend and reliable source tells me the rims from a M-151 MUTT Jeep will not fit the CJ2A.
Is it the bolt pattern or the center hole that's the problem?? (both?) He has several sets of 4.
tires & wheels
tires & wheels
DSCF1844 (200 x 150).jpg (9.72 KiB) Viewed 1817 times
skinnedknuckles
Re: Jeep Wheel Question!
Post by skinnedknuckles »
Tim , If memory serves me right , I think they will physically go on but something with the way they locate on the hub is screwy. I know Jeep wheels locate off of they the lug nut tapers but I am not sure about mutt wheels, didn't the lug nuts have a washer attached to them kind of like the hub pilot wheels on todays big rigs? I had a 1969 CJ 5 years ago that someone had put mutt wheels on and took them off right away because I didn't like how they fit on.
Have fun fixin' its a great hobby :D
Paul in Wisconsin
Paul in Janesville, Wisconsin
1953 m37 parts truck
MVPA and MVPG member
Tim Powell
Thanks Paul.
Almost everyone I've talked to had said the same thing. Some little difference in the wheel keeps them from mounting the hub properly.
I'll most likely buy at least one set and if my rims are as bad as I think they are I'll just try and find another set of wheel.
Wish I owned a tire machine! I'm getting too old to change tires by hand and too cheap to pay someone else to do it. :evil:
Master Yota
Post by Master Yota »
Tim Powell wrote:Thanks Paul.
I have access to a tire machine, I just wish I had access to someone else to operate it....lol
Either that, or run lighter tires...lol
52PLOWERWAGON
Post by 52PLOWERWAGON »
they fit fine I have some on my 46 but i'd get wheel spacers or just put them on backwards because they rub in the front :)
Thanks,TRAVIS
1952 M37 FARM TRUCK
1941 WC RATROD
Tim Powell
Problem solved!! Found a set of proper wheels out in Nebraska!
