m37 axle
squeeky0_50
m37 axle
Hello, anyone know the distance in inches from floor to bottom of axle assembly for jackstand clearance to remove 4 tires. My truck is on its way home to me and I have no idea how tall a jackstand I need under the 4 corners of the axle. Would appreciate any info, thanks.
Re: m37 axle
any standard height 3 ton jackstand will be plenty good for your task, here is a example:
http://www.harborfreight.com/3-ton-heav ... 38846.html
Re: m37 axle
I bought two Powerbuilt stands about a year ago and haven't had any problems with them . There rated at 3 tons and I find them easier to use then the regular jack stands .
http://www.tractorsupply.com/en/store/p ... _vc=-10005
Sal
Sal
1954 M37 WO/W
1969 M101A1
1969 M101A1
Re: m37 axle
15" from driveway to under side of axle housing with used 900-16 NDT.
