OIl fill tubes
OIl fill tubes
i have an M37 here I picked up that still has aT245 in it but the oil fill tube is a press in fit. I thought the T245s were all bolt on oil fill tube. When did they switch to the press in? or was it vice versa?
- pwrwagonfire
- SSGT
Re: OIl fill tubes
My M-37 has a Chrysler industrial engine 230 which I installed in it...everybody said that the tube should be pressed in, but it's bolted in. We may never know!
-T
-T
Re: OIl fill tubes
no theories? do any of your T245 engines have a press in tube?
Re: OIl fill tubes
Seen a lot of T245 engines none with press in tubes, maybe a prototype block?
Re: OIl fill tubes
I was thinking maybe a replacement block. The late war T214s in the WC 3/4 and 1 1/2 tons were already getting bolt on tubes, five years before production Ms existed. the bolt on is a way better set up.Carter wrote:Seen a lot of T245 engines none with press in tubes, maybe a prototype block?
Re: OIl fill tubes
Replacement block with a hand stamped number maybe? Lots of blocks left over after WWII I suspect, puzzling to say the least.
Re: OIl fill tubes
My 53 has a pressed in tube , but also has the studs for a bolt on tube , engine was rebuilt when I got my MV , so who knows when it was done .
