Hi Guys,
I'd like to find the registration numbers on my truck. The hood had been previously stripped to bare metal and repainted, so those numbers are long gone. But I was looking at the tailgate yesterday and I can see OD paint underneath 2 layers of fire engine red paint. The top layer is dull and flaking off, but the second red layer seems well bonded to the OD and is still shiny. So what I'm looking for is the best way to get to the OD without destroying it. I thought about using a liquid stripper, as they usually remove one layer at a time, but it's the "usually" part that bothers me. I could use sandpaper and attack it by hand, but I figure I'd ask you guys what you've done, as hindsight is 20-20 and some of you have been there and done that.
So let me know your recommendations for how not to screw this up................I appreciate it in advance.
Best Way to Remove Old Paint To Find Registration Numbers
Re: Best Way to Remove Old Paint To Find Registration Number
Hi Bob,
Block sanding by hand is the way I found to work my way down thru the layers.
- CPL
Like Bert said, block sanding works for me. On my t-24 weasel I actually had to wet sand the areas just because the numbers and letters were so faint and hard to read.
Paul
Paul
Paul in Janesville, Wisconsin
1953 m37 parts truck
MVPA and MVPG member
- m37jarhead
In the pic of my M37 hood, I used a razor blade holder like the ones used to remove paint from windows. I would guess the amount
of success you'll have with this method is dependent on the quality of the preparation done before the new top coat(s) were
sprayed over the O.D.
The yellow, white and other colors easily came off of the O.D. probably because no one sanded or scuffed the O.D. surface prior to
spraying on the new paint. Like many of us, I was just trying to find the hood numbers but since the paint "schards" zipped
off so easily, I did the whole hood surface. Same method was used for the artic top, fenders, doors, etc. and any other relatively flat surface.
As you can see in the pic, the original O.D. paint refused to submit to the razor. The surprise was how well the
hood numbers were revealed.
The second pic shows the same numbers on the firewall. Another surprise! Used the razor blade method here too. I added the dashed
lines and the 18" markings for future reference.
Experiment first on other areas before you get to the hood numbers. Catch a crack or sharp edge on the paint and with a little
experience, you'll establish just the right "touch" to get the paint schards flying. Wear safety glasses 'cause the shards WILL
fly into your eyes...... trust me on that.
Jerry Bubolz
Jerry Bubolz
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Past Pres
Member: MVPA #26600
Member: NRA
