As my restomod is moving along I'm coming up with quite a few parts that I'm not sure what going rates are, so will entertain offers if the interest is there. All of these parts were pulled from the truck which was running at the time of removal
24v working voltage regulator. Have the pigtail coming out of it but not the full harness
24v working generator
24v working starter
full gauge set and senders *better half has me keeping the speedo
Manifold set
Carb
Fording air cleaner
I think that's it for now... If you're interested we can discuss trades or cash.
The electrical stuff was removed for a 12v conversion, and I am 95% sure that I am going to have a custom dual carb manifold set made so that's the rest of those parts.
Various parts from a '51
- pwrwagonfire
- SSGT
Re: Various parts from a '51
Talked with Tom,
Exhaust manifold is mine
-T
-T
You wouldn't have the cab bow and the extinsions? Because the last guy I talked to will not ship the one he has.tbone1004 wrote:As my restomod is moving along I'm coming up with quite a few parts that I'm not sure what going rates are, so will entertain offers if the interest is there. All of these parts were pulled from the truck which was running at the time of removal
24v working starter
Manifold set
Carb
Fording air cleaner
Later joe
unfortunately not. I'm keeping the door frames but that was all that was left when the VFD removed the soft top and replaced it with the chevy top
Thanks for the reply. Chevy cab top. Hum that would be neat to see.tbone1004 wrote:unfortunately not. I'm keeping the door frames but that was all that was left when the VFD removed the soft top and replaced it with the chevy top
Later Joe
check the build thread "Walter"
pictures in there of the top
ok, now with the V8 swap in progress I've ditched the dual carb thing and the other Tom was able to find a second manifold in good shape in his parts bin so that is now up for grabs.
I'm looking for a drivers seat without springs if anyone happens to have one of them
4bbl Edelbrock finned air cleaner
Helitool hanging pedal setup
and I think that is about it for stuff that I need/want, otherwise cash is king. Will try to get a bunch of pictures today of everything. Been a very crazy month at work so I apologize for not getting them up sooner.
Do you still have the Fording shroud for the Air Cleaner?
52 M-42
52 M-42
I may be interested in the generator if you have it. Is it just the 25amp?
1951 M37 w\w
Marcus in NC
Marcus in NC
