360 LA to NV 4500. What Clutch?
antpreson
Post by antpreson »
I am trying to mate a dodge 360 gas engine to a NV 4500 transmission. Is there a bolt on clutch that I can use?
antpreson
Re: 360 LA to NV 4500. What Clutch?
Post by antpreson »
anyone? anyone?
JimC
Post by JimC »
What is your input spline count and shaft diameter?
Frank Irons
Post by Frank Irons »
antpreson wrote:anyone? anyone?
Do you mean the clutch housing(bellhousing) or just the clutch assembly? The clutch assembly is a standard Dodge truck clutch, the bellhousing will have to come from a late model Dodge truck with the NV4500 trans. I bought my clutch housing from Chrysler, I think it was about $230 new.
Frank
antpreson
Post by antpreson »
I have the bell housing. I just need the clutch assembly. My transmission guy gave me two 10 spline input shafts to pick from. one is for a diesel engine clutch and the other is supposed to be for a gas engine clutch.
JimC
Post by JimC »
Keep in mind that the Dodge and GO shafts are different. Which is your transmission out of?
