M37 parts truck
MDSA
M37 parts truck
Post by MDSA »
Have a parts truck with CCKW axles and CCKW transmission. Trans has a PTO. Engine is a Chevy six.
Body mostly there. Bed is heavily modified, doors and cab are cut up or rusty, but many good parts.
Located in Western North Carolina.
Front fenders. 50 each. Some small rust through SOLD
Hood. 50
Grill/headlight guards. 25 all 3
Bed - modified. 100 SOLD
Radiator. 250
Winch bumper extensions. 40 both SOLD
Windshield frame - no glass. 50 SOLD
Running boards. 35 each
Battery box/lid. 25.
Front shackles/mount 25 each
Hood sides. 25 each
Rear fenders. 25 each SOLD
Tool door. 15 each
Rear bumpers. 25 each
LU4 winch, PTO, driveshaft 1000
100 amp alternator, regulator. 150
16" Combat rim - 50 SOLD
Miscellaneous M37 parts - ask
Re: M37 parts truck
Hi Brian,
I'm looking for the two brackets that are just above the large windshield frame clamps. These have two bolt holes each and the window frame pulls down to them. I would also need the four bolts and washers.
MDSA
Re: M37 parts truck
Post by MDSA »
Do you mean the clasps on the hood?
Re: M37 parts truck
Brian,
Not on the hood.
These are inside the cab and bolted to the dashboard just above the large windshield clamp.
snowdad
Re: M37 parts truck
Post by snowdad »
Good evening. Do you still have the 100 amp alternator or is it the generator? Looking for a backup unit with regulator as my truck was an m-42 at one time and want to keep it stock
sturmtyger380
Re: M37 parts truck
Post by sturmtyger380 »
How are the rear fenders? Can you send pictures? Alan
Jimdmaine
Re: M37 parts truck
Post by Jimdmaine »
I could use the passengers side running board if its not dented. You can reach me at jdewolfe362@gmail.com
