Transfer case question np200
Hi all, i need to know what the travel distance is that the shift rails move in and out when shifting the transfer case. i am working out of town and my wife at home wont crawl under my truck to measure
. thanks for any help, fodman
jimmy_stikx
- SGT
Re: Transfer case question np200
Are you talking about the things the levers attach to? if so, mine look about an inch or so. I could measure the throw while I degrease the outside.
yes that is what i need,thanks fodman
i was going to offer up measuring my spare transfer case in my garage if nobody else responded. If you find you still need particulars, let me know.
yeah i still need the measurement, installing an airshift and i have to have that info to get the correct air cylinders. thanks fodman
Ok Fodman,
I can check that this afternoon and post the numbers.
A day late but here you go: both of my transfer case shafts moved 5/8 of an inch from full-in then out to the ball-stop.
Thanks for the info, just what i needed. fodman
Glad to help!
