Vent Drain Tube Q?
Vent Drain Tube Q?
In looking to repair some rust holes in the drainage ditch around the center pop up air vent, I noticed a welded drainage tube nipple about 1" long. If I repair the ditch, obvoiusly there needs to be a tube added to drain water. Question is size/length of hose and where does it drain out to?
- PFC
Drain Hose
knattras,
I just installed a couple of feet of heater hose on my M37.
I ran it off to the passenger side to drain away from the engine compartment.
Longhunter7
Northern Illinois
63' Dodge M37-B1
Molon Lave
NRA Certified Weaponologist
Northern Illinois
63' Dodge M37-B1
Molon Lave
Vent drain
Mine also exits through te firewall and onto the top of the block, os I must get a longer hose. It appears to be nothing more than about 5/8ths heater hose....
