Hi Guys,
I'm not that familiar with military designations in general and know nothing about military trailers. If I wanted to get a trailer for my M37 from the 1952 time period what model should I be looking for?
What Trailer for my M?
- sturmtyger380
Re: What Trailer for my M?
Hi Bob,
You might want to look for a M101 Trailer. It is a 3/4 ton trailer and matches the M37 well. You could also look for a WWII Ben-Hur trailer but those are more scarce and not as much cargo capacity as the M101. There are a number of M101 trailers that are surplus right now.
Check this out: http://olive-drab.com/idphoto/id_photos ... railer.php
Alan
Alan
The M101 trailer was designed for use with the M37 and uses the same tire and wheel so it's a good match.
M101 rebuild pix: http://news.webshots.com/album/550941539aSwjue
The M101 for the 50 to 53 period would be a perfect match but are hard to find. The M101A1 from about 54 and up to about 68 would work just as good and from there on you must be careful which M101XX series you pick as the wheel and tire and the brake system changes.
