Speedo Gear Help
Speedo Gear Help
I replaced the original 5.83:1 gears in my M37 with 4.89:1. I'm looking for a little information on what speedometer drive/driven gears I need to use in the transfer case to get the speedometer to read correctly. Thanks, DW
Re: Speedo Gear Help
Hi, You might try a ratio adapter from these people. http://www.transmissioncenter.net
I put an electronic speedometer on my M-37. Didn't have a drive cable and the speedometer didn't work.
Regards,
Paul
Wasilla, Alaska
Regards,
Paul
Wasilla, Alaska
Thanks Paul. I'll give them a shout.
