Front lifting shackle question
dispatcher1011
Hello all,
On my 1954 M37, WO/W,I have a question about the front lifting shackles.
Is there a spacer or something I am missing for the back bolt?
The two front bolts go through the bumper/frame, and they sit flush.
The back single bolt has a gap between the frame and shackle.
How do you guys deal with that space? Stack of washers?
I never had a bumper on my truck, so I don't know if I am missing pieces or not.
Thanks!
Thanks!
Re: Front lifting shackle question
I am going to check my rig for you. But I don't think I have any washers (either type) on my front bumper.
Mine has a washer or maybe a spacer in the gap. I can't swear that mine is original. Looks like this: (Don't mind the color shift, had to use a flashlight so the camera would focus.)
No washer/spacer on mine either.
nortonscustoms
I just took off my bumper and lifting shackle brackets this weekend. There was spacers/thick washers for both back bolts . Under the million different layers of paint, the spacers and bottom of the brackets were the original OD so I'm guessing the spacers are original as well.
I havw always seen spacers that look like fat big washer under mine (I have seen at least 5 M37s)
1962 M116A1 Generator trailer
1964 M101A1 3/4 ton trailer
Does anyone here have a lead on these brackets? I have the shackles now but my truck was missing the bracket.
Try Bob Stahl, he should have some lying around.
Bob or AB Linn should have them. I just looked at mine, apparently I have the spacer/washer.
I just couldn't see them in my webshots albums?
Spacer, Steel, cadmium or zinc plated, 17/32" ID x 1 1/4" OD x0.171" thick quantity 2 each for front lift shackle brackets.
Chrys # 1268318 and ORD # 7705781
I installed washers under my back bolts-didn't like the thought of so much torque on the front bracket holes due to the downward pressure from the back bolt.
These are nothing more than extra thick flat washers; easy to get, just check the mcmaster-carr catalog in the flat washer section.
