Serial Number
Serial Number
Hello, again. I wanted the year of manufacture, quantity and other data that may arise from the Serial Number of my M37.
The Serial Number is: T 245 02044
Thank you very much
Carlos
Thank you very much
Carlos
Re: Serial Number
Are you sure about that number? Where did you get it from?
Check out this page of this web site:
http://www.g741.org/ProductionDates.html
Re: Serial Number
Yes, I'm sure. The number is on the chassis of my M37. My M37 was imported to my country (Argentina) by the local army.
cuz wrote:Are you sure about that number? Where did you get it from?
Re: Serial Number
Carlos,
This looks like an engine serial number. Did you look on the frame in the left front wheel well? It should be punched into the frame rail there.
Re: Serial Number
That number is under the left front wheel
repealThe17th
Re: Serial Number
carlos, try this search...
http://www.g741.org/m37registry/search.php
and at item 1 - 'serial number' type 't245' then click the 'search and report' button at the bottom of the page.
you will see that 3 other trucks have a 't245' serial number and are from 1960. yours may be also.
btw, does anyone know anything about 't245' serial numbered trucks? like why they broke with the normal numbering scheme? or anything else about them?
Re: Serial Number
I can not find an answer on that page. Maybe I do not know how to enter data spaces.
My details:
M37B1
Serial Number: T24502044
Engine Number: T245A200775
My details:
M37B1
repealThe17th wrote:carlos, try this search...
Re: Serial Number
Two of the three serials listed starting with T245 XXXXX are in Argentina and one is in Howe Tx.
The link above is for the query page and you must enter a query. Here are the three trucks with numbers close to yours:
http://www.g741.org/m37registry/display ... nercount=1
If you go to this web sites "Production Dates" page you will find this:
This info would lead me to believe a batch of M37B1's were built for export to Argentina in 1960 and one found it's way back to the US in Texas.The following pages list the M37 series production dates, serial number and quantities. Each table covers a specific serial number range, there were five distinct serial numbers used, 800xxxxx, 802xxxxx, L245-xxxx, 2661-xxxxx, 2668-0-xxxxx. In addition to this official list of serial numbers, I have one report of an M37 serial number T245-xxxxx. This vehicle also has a delivery date of 1960, when no M37s were shipped. Perhaps a B1 prototype?
800xxxxx, Spring 1950 through July 1953, M37
802xxxxx, July 1953 through January 1955, M37
L245-xxxxx, April 1958 through June 1959, M37B1
2661-xxxxx, January 1961 through December 1962, M37B1
2668-0-xxxxx, January 1963 through December 1968, M37B1
Production summary
repealThe17th
Re: Serial Number
cuz, you wrote "This info would lead me to believe a batch of M37B1's were built for export to Argentina in 1960 and one found it's way back to the US in Texas."
i suspect there is more to the mystery of the 't245' serial numbered trucks as i know of other one in new hampshire. if anyone has the whole solution, i'm all ears. probably so is carlos.
Re: Serial Number
I'm from Argentina. M37 in my titles says it is 1968 model, but may be a mistake of those who entered the data.
Carlos
Carlos
Re: Serial Number
There is a little bit of information in Zentmyer's book on the M37. Chrysler switched to model year production (July-June) from calender year production (Jan - Dec) in 1960. He states no 1960 model year trucks were shipped. The serials on 58-59 trucks were prefixed with L245 XXXXX and he gave an example of serial prefix as T245 yet he does not list any T245 serialed trucks. Then he goes on to say the first trucks shipped on the new model year system were the 1961 model year which began in July 1960 and their serial was prefixed 2661-XXXXX. It may be that those very first 1961 trucks built in July 1960 used the old serial prefix system with the T245 prefix.
