general
Carlos
general
Post by Carlos »
Hi, again with my questions
That means TP45?
For sive metal handles are on both sides of the box?. This photo is top right:
Muchas gracias desde Argentina!!!
pfrederi
Re: general
Post by pfrederi »
TP 45 is Tire pressure 45 pounds per square inch or 3.1 BAR
Paul f
Carlos
Re: general
Post by Carlos »
Thank you very much pfrederi !!!
Carlos
Re: general
Post by Carlos »
Re: general
Carlos,
As to your arrow in the above pic, I believe those are the anchor brackets for the canvas strap that hold down the Cargo top bows in the "stored" position.
Re: general
David you are correct!
Carlos
Re: general
Post by Carlos »
Ahhhh thank you very much!
I'm learning little by little
Thanks David, Gary and Paul
majorhitt
Re: general
Post by majorhitt »
The bolts in the picture look like hex head bolts. When they took the straps off the Phillips head screws were probably tossed out and the hex head bolts installed. As mentioned earlier this bracket is used to strap down the cargo bows in the stored position. Ed
Carlos
Re: general
Post by Carlos »
Thank you very much Ed!!!
majorhitt wrote:The bolts in the picture look like hex head bolts. When they took the straps off the Phillips head screws were probably tossed out and the hex head bolts installed. As mentioned earlier this bracket is used to strap down the cargo bows in the stored position. Ed
