Moderators: Cal_Gary , T. Highway , Monkey Man , robi
M37UK
Posts: 460 Joined: Fri Oct 24, 2008 12:38 pm
Post
by M37UK » Thu Jul 07, 2011 6:38 am
This one has me puzzled. Does anyone know what kind of latch/hook etc is supposed to be fitted to the rear sliding window of
the arctic cab to stop it sliding around when I go round corners ?
Maybe its supposed to be a friction fit but I aint sure
Anybody out there any ideas?
Cheers
Stu
MVT UK
SMVG Scotland
Posts: 1840 Joined: Sat Oct 20, 2007 4:48 am
Post
by Carter » Thu Jul 07, 2011 7:58 am
No latch on mine and no sign there ever was one.
Posts: 2096 Joined: Sat Oct 20, 2007 3:50 am
Post
by Lifer » Thu Jul 07, 2011 8:17 am
I think that, like most sliding windows, they were a friction fit. Those weather strips do tend to lose their grip a little after the first 50 years or so.
DJ
Posts: 276 Joined: Fri Oct 19, 2007 8:28 pm
Post
by DJ » Thu Jul 07, 2011 1:42 pm
OD bungee cord ??
m37jarhead
Posts: 647 Joined: Sun Jan 06, 2008 6:55 pm
Post
by m37jarhead » Thu Jul 07, 2011 7:19 pm
Friction fit only on mine. No latch or detent stops. If yours is sliding around you just need new
weather stripping to fix the problem. Or you could just slow down around those curves.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
M37UK
Post
by M37UK » Thu Jul 07, 2011 9:34 pm
Thanks all
I will look into the weather stripping.
Stu
MVT UK
SMVG Scotland
Posts: 1822 Joined: Thu Jul 09, 2009 4:57 am
Post
by T. Highway » Fri Jul 08, 2011 3:25 am
If your driving so fast around corners, how about using OD 100 MPH tape to keep it closed?
M37UK
Post
by M37UK » Fri Jul 08, 2011 11:01 am
T. Highway wrote: If your driving so fast around corners, how about using OD 100 MPH tape to keep it closed?
haha, its not the speed round the corner that does it, its the sharpness of the corner. We dont have straight roads in Scotland
Stu
MVT UK
SMVG Scotland
m15256
Posts: 131 Joined: Fri Dec 26, 2008 6:00 pm
Post
by m15256 » Fri Jul 08, 2011 5:55 pm
No latch on mine. I think one of the jack stands would have to fall over for it try and slide much.
RICK
M 152 CDN
M 56 (V41)
hbb
Posts: 282 Joined: Fri Jun 26, 2009 6:59 am
Post
by hbb » Sun Jul 10, 2011 7:20 pm
I believe scotch locks or maybe some scotch tape might be in order ! Sorry I just couldn't resist that.
hb
M37UK
Post
by M37UK » Sun Jul 10, 2011 11:56 pm
hb wrote: I believe scotch locks or maybe some scotch tape might be in order ! Sorry I just couldn't resist that.
hb
Lol, thats a good idea HB!
Stu
MVT UK
SMVG Scotland
m37jarhead
Post
by m37jarhead » Sun Aug 07, 2011 7:42 pm
Speaking of Scotch, maybe with a few hits of single malt you wouldn't notice or even care if the artic cab window
slides around.
Past Pres
Member: MVPA #26600
Member: NRA
hbb
Post
by hbb » Mon Aug 08, 2011 12:23 am
Line em up and I'll pour when were done with the Scotch we"ll salut the Crown,,,,, Royal!
Then we surly won"t sare if it's open or not Problem solved we fixed it.
hb
anthony manzella
Posts: 292 Joined: Sat Oct 27, 2007 4:08 pm
Post
by anthony manzella » Mon Aug 08, 2011 5:36 am
Try Some Warm Sheep Dip ? Na ! Na ! Na ! Ha Ha ,
" went to my local hardware store and pick up a 12''x12'' square pice of rubber sheet, Cut about 3" pice and fold in half and stuff it in the passeger side between the window and back of cab , it also keeps it from ratteling .
Hit Duh Ground Runnin
