Need NAPA # for points/ condensor
Nickathome
Post by Nickathome »
What is the NAPA number (if any) for points and condensor for M37's? Would like to have a spare set to keep in the truck now that its legal, thanks.
Jim_n_Tx
Ignition
Post by Jim_n_Tx »
I have not had any luck with my truck running well (it's 24v) except with condenser from military vehicle suppliers (last from Midwest Military). I tried local sources - they said they were right, BUT not.
1942 WC-54
There was a cross-reference list on the old Big Electric forum at one time. I downloaded it for future reference, but I'll be hanged if I can find it now! :(
Re: Need NAPA # for points/ condensor
Nickathome wrote:What is the NAPA number (if any) for points and condensor for M37's? Would like to have a spare set to keep in the truck now that its legal, thanks.
Condensor, AL869, Points, CS725A
peter e mark
Post by peter e mark »
You sure are on top of things, Mr. Talbert...
1952 M37 W/W
Nickathome
Charles?....
Those napa numbers, they are for a 24 volt system I assume? My truck is still 24 V, I should have included that, thanks.
M-Thrax
Post by M-Thrax »
Voltage doesn't matter
Both my 37 ( 24v) and my WC-21 ( 6v pos grd ) used those #'s.
Also the napa # for the M-37 rotor is AL 166 ( now those are different in each vehicle)
Nickathome
Voltage...
I wasn't aware that voltage isn't a concern when orderin gthese items. I had thought it would be an issue....Thanks
M-Thrax
Post by M-Thrax »
" I had thought it would be an issue"
Yeah me to!... but the things you learn in this hobby
g741
Distributor Parts
Post by g741 »
When you go to the Auto Parts Store, be sure to specify Standard Brand. They still make stuff in the USA. Their caps, points, condensors etc. seem to work fine. Costs more though. For example, I needed a 12 volt coil for my Power Wagon Restoration. The made in USA version was $47 and the foreigh version was about $15! I opted for the US made coil. You may not find Standard Brand at NAPA. I buy them at a local Car Quest. Sid
Thanks for the tip, Sid. After all, what's another $32 or so in the overall scheme of things? It's only money! :)
Nickathome
Re: Distributor Parts
g741 wrote:When you go to the Auto Parts Store, be sure to specify Standard Brand. They still make stuff in the USA. Their caps, points, condensors etc. seem to work fine. Costs more though. For example, I needed a 12 volt coil for my Power Wagon Restoration. The made in USA version was $47 and the foreigh version was about $15! I opted for the US made coil. You may not find Standard Brand at NAPA. I buy them at a local Car Quest. Sid
Sid;
I bought a set the other night. NAPA had exactly the numbers that Charles mentioned and they are made in good old USA because I checked.
Hey BTW - Do you remember a short while ago I had inquired about the arm that raised and lowers the cowl vent? Was wondering if you still have one. I remember yo uhad responded but were away on business. I forgot to get back to you about it sorry. If you have any of these arms, I'd like to place an order for one, thanks.
CGarbee
Post by CGarbee »
Lifer wrote:There was a cross-reference list on the old Big Electric forum at one time. I downloaded it for future reference, but I'll be hanged if I can find it now! :(
The cross reference list that Pete Ruffing put together (he updated and expanded upon Bill L's list) is posted on my website in PDF form at:
http://www.garbee.net/~cabell/PartsCross.PDF
It is the one that Eric had linked to from the site when it was BigElectric...
As always, I'm interested in updates, corrections, expansions, to the list...
Enjoy.
'53 USMC M37 w/Cummins 4BT
'64 XM708,
'51 M38
Thanks, Cabell. I printed it off again and I'll try not to lose it again. ;)
Wouldn't you know it?? I just filed the reprint in my M37 paper folder with my various assorted receipts. When I picked up the folder, the original copy fell out from behind some other stuff! DUH! :oops:
