What is the best CD on M37 manuals to buy?
Paddyofurniture
Post by Paddyofurniture »
I am looking for the best CD on M37 manuals to buy?
With the maintenance and parts manuals.
Paddyofurniture
cuz
Re: What is the best CD on M37 manuals to buy?
Post by cuz »
The Emilitary manuals CD i got a while back came with 6 WWII WC manuals labeled as M37 manuals and listed a -34P but it was not on the CD.
These are:
TM 9-1808A Engine Clutch and Electrical Systems tm9-1808a
Section 1: M37 series vehicles covers engine and sub groups clutch, engine repairs made in and out of the truck. Next is removal and full tear down engine and sub groups. Inspection and repair of the engine assembly with install back in the truck. Includes a data base of fits and tolerances for the engine.
Section 1: M37 electrical system is described and includes electrical trouble shooting. This covers removal of components and repairs with replacement including Starter, generator, regulator, ignition, distributor, Full electrical trouble shooting, rebuilding and fits / tolerances for electrical units. Comes with wiring circuit diagrams of all electrical circuits. tm9-1808a
TM 9-1808B M37 Maintenance Power Train / Chassis / Body M37 Dodge and 6x6 Dodge detailed construction of the unit, disassembly and assembly procedure, inspection, maintenance and repair. diagnosing HI transmission / power takeoff transfer case, drive shafts, uv joints, rear axle, differential, axles.Data base of fits and tolerance power train, brakes, steering, frame, springs, shock absorbers, winch, chassis, body. tm9-1808b
TM 9-808 M37 Operating / Maintenance Instructions
Section 1: M37 operating instructions, controls, auxiliary equipment, preventive maintenance, lubrication.
Section 2: M37 truck maintenance trouble shooting, engine, maintenance adjustment in the vehicle, engine removal with reinstall, fuel - exhaust - cooling - battery- systems. tm9-808
SNL G-502 M37 Military Vehicle ¾ ton Dodge Parts listings includes model ID WC-51weapons carrier, WC-52 Army weapons carrier / winch, WC-53 military truck general purpose, WC-54 military ambulance, WC-55 military arms carrier, WC-56 command truck, WC-57 command / winch, WC-58 army radio truck, WC-59 phone and utility truck, WC-60 emergency repair truck, WC-61 phone maintenance truck, WC-64 KD ambulance snlg-502
SNL G-502C M37 Army Technical Manual Changes M37 military vehicle service parts including / body. suspension / drive train, transmission / transfer case, power take-off / winch assembly, engine assembly, exhaust, fuel, cooling, electrical, ignition, chassis snlg502c
