M37 parts list
M37 parts list
Mitch wrote:
> *Editing for parts sold*
> These are the loose parts that I have. I also have two pretty complete
> parts trucks so if it ain't on the list I may have it on one of the trucks.
> Prices do not include shipping!!!!!
> 1) 1ea military rim. I was told this was for a M715. Make offer
> 3) 1ea water elbow. *NEW* $15.00
> > 5) 1ea 4blade cooling fans. *takeoff* $20.00
> 6) 1ea 180deg Thermostat *NEW* $15.00
> 11) 1ea ebrake "J" bolt. *takeoff* $3.00
> 12) 1ea Fan pulley spacer *takeoff* $5.00 ea
> 15) 1ea ebrake band. Needs relining. $10.00
> 17) 2ea wiper blades *new* $5.00ea
> 18) 1ea turn signal set. The lever and control box look like takeoffs but
> there is a wire set that is new in the bag. $150.00
> 19) 2ea battery cable grommets. I think these are for the battery cables
> running to the slave recpt. *takeoffs* $3.00ea
> 22) 2ea blackout light brackets. *takeoffs* $20.00ea
> 23) 1ea fuel pickup. *takeoff* $10.00
> 24) 1ea weatherstrip. I think this is a piece of outer weaterstrip for the
> doors *NEW* $5.00?
> 25) 1ea dipstick *takeoff* $5.00
> Alright, I'm gettin tired of typing!!! I'll add a reply to this post with
> the rest of the stuff. I probably have another 25 or 30 items left to list.
> doors *NEW* $5.00?
Re: M37 parts list
I'll take the choke,take off fording and throttle cable. Ships to 98280. Thanks Brett
52 M38
53 CJ3A
53 M37
53 CJ3A
53 M37
Re: M37 parts list
Mitch,
I'm looking for take-off windshield wiper arms (not the wiper blades) and a set of unmolested ventilation lines that go from the air intake assembly to the distributer (mine are all bent up and I would very much like to replace them).
Kevin
Kevin
Re: M37 parts list
Mitch wrote:
> *editing for parts sold*
> Ok guys here is the second part of the list.
> 27) 2ea Glove box doors *takeoffs* $25.00 ea
> 29) 2ea used Master Cylinders Rebuildable? Make offer
> 30) 2 ea outer door handles *takeoffs* $10.00 ea
> 31) 1ea shock mount. I think this is for the front axle *takeoff* $30.00
> 33) 4ea vacuum wiper motors. 2 have large handles 2 have short handles. I
> worked these by hand and they feel like the seals are good. They would pull
> vacuum on the tube when manually operated. $50.00 ea
> 34) 2ea Windshield adjusting arms. *takeoffs* $10.00ea
> 35) 2ea taillight brackets *takeoffs* $10.00ea
> 36) 1ea tcase or ebrake shifter rod. $20.00
> 37) 1ea windshield latch *takeoff* $5.00
> 39) 1ea inside door handle *takeoff* $10.00
> 40) 1ea wiring protector channel. This is one that goes under the front
> fender *takeoff* $10.00
> 41) 2ea headlight trim rings *takeoffs*$20.00ea
> 42) 4ea Battery Lugs *NEW* 2ea POS 2ea NEG$5.00ea
> 43) 4ea Battery lug covers. *NEW* 2ea red 2ea black $20.00 for the set
> 44) 3ea front turn signals Looks like 2ea drivers side and 1ea passengers
> side. 1 has red oval at top one has clear oval at top and the pass has two
> clear rectangular windows. *takeoffs* $20.00ea
> 45) 1ea starter switch. This is the one that fits on the starter. *takeoff*
> $30.00
> 46) 1ea trailer recpt cover. *takeoff* $6.00
> I also have several other brackets, lug nuts etc that I wasn't sure of on
> identification. Let me know and I'll send you pics of them and we can make
> medicine!!!
> Once again, that is just the list of the loose parts I have. There are a
> couple more things I will list later that I haven't had a chance to check
> out well yet. There are also two trucks that I have that are pretty much
> complete, ,motors, trannys, starters, generators,regulators, axles,
> springs, doors, bumpers, headlight buckets, fenders, tailights, brake drums, tires, rims, hubs etc, etc.
> I will be glad to send photos of parts for anyone that wants to look at
> them first. Just let me know and I'll do what I can to help you out.
> $30.00
> medicine!!!
Re: M37 parts list
Happen to have 1 front black out marker light cover?
Re: M37 parts list
Hi Mitch,
I'm restoring my '52 M37 which has some rust. I'm looking for the frame to fender brackets on both front sides along with both complete running boards and brackets to frame.
Thanks.
John
Thanks.
John
Re: M37 parts list
Hi!
I need the radiator cap....I will send you a PM
Thanks!
Ty
Thanks!
Ty
Re: M37 parts list
Hey Mitch,
Have you entered the info from the T/O glove boxes onto the M37 Registry? Doing so eliminates any speculation about the truck and it's where-a-bouts in the future.
Regards,
Regards,
Re: M37 parts list
I think I had already registered them. I will double check that though.
Re: M37 parts list
Got some more stuff from Mitch the other day... Just the thing to get my M squared away...
Re: M37 parts list
Hey guys for those of you that have contacted me about parts and anyone else interested in any parts, I will be out of town the week of the 10th thru the 17th. I may not have computer access so if I don't answer you immediately bear with me and I'll get back to you asap. Thanks!!! Special thanks to all those folks who have purchased parts up to now.
Re: M37 parts list
Mitch wrote:
> Mitch wrote:
> > Ok guys here are a few more parts that I have gotten around to as I have
> > been removing parts off the two parts trucks
> > 1) Three trannys. two are takeouts from the trucks and one was sitting in
> > the back of the old truck. $150 ea for the takeouts and $50.00 for the
> > sitter!
> > 2) 2ea Intermediate shafts. These are the ones that go between the tranny
> > and the tcase. Take outs, good shape $50.00ea
> > 3) 1ea bellhousing. This has the clutch fork in it and I'll throw in the
> > throw out bearing,spring, inspection covers and the throttle bracket that
> > is still attached to it!! $65.00
> > 4) 1ea Flywheel. good shape w/ring gear $40.00
> > 5) 1ea Pressure Plate good cond $50.00
> > 6) 2ea shifters one is in grat shape with the knob, the other has no knob
> > and the threads are broken off. Should be easy enough to weld a bolt on or
> > evem thread the shaft to get a knob on. $15.00 for the good one $5.00 for
> > the other
2ea tcase shift levers ebrake lever sets *takeoffs* $40.00ea
> > 9)2ea doors. These are complete with windows, locks, handles, hinges,
> > access panels etc. $125.00ea
> > let me know if you need any body parts, springs, axles etc as I still have
> > pretty much two sets of most of that on the two trucks.
> > sitter!
> > the other
Master Yota
- MSGT
Re: M37 parts list
Do you have a passenger seat bottom?
Re: M37 parts list
If you are talking about the cushion, no I don't. I sold the only set of seat cushions that I had already.
