Well she now has HEAT! Only did a quick check in the shop as it was dark, but the water flows and she blows. The two flex hoses are for defrosters, and the grill has a damper so I can increase the defrost hose flow. The hoses do whistle with the damper shut, so I may be looking for a non-rib'ed hose at some point
My M now has Heat!
- W_A_Watson_II
My M now has Heat!
Nickathome
Heat
Very nice setup. How do you have the hoses routed for the defrosters?
- W_A_Watson_II
