Radio Installation
Radio Installation
Since it appears that my truck may have had a radio installed, because of the antenna mounting holes found on the bed. My question is where would the radio be mounted in the truck? Also which radio?
Right. The radio mount bolts to the seat. Then the radio and the power supply slide/drop into the mount. My Brother in Law`s truck has more holes on the bench making us think that it had a few radios in there. My M42 rig has new wood but it has a airial mount on the bed and the power supplu plug in the front of the bed...
Rusty S.
Are there pictures of M42 table
Looking at the pciture above I am wondering if anyone has drawings of the table used as part of the M42 command version of the M37. I would like to make my own.
The type and number of radio sets would be entierly dependent on the requirements of the unit assigned the vehicle. Radio installation kits would be used to install a radio set in the vehicle, it would include detailed instructions w/ drawings and all the parts needed to install the set. Generally the first radio set goes on the troop seat at the left front(behind the driver) the 2nd set on the left rear troop seat, a third would be right front troop seat and a fourth would be on the right rear troop seat position. A vehicle w more than a single radio would also likley require the 100 amp charging system to be installed to supply enough power. Each type of radio set uses a paticular mount which would be secured to the troop seat also a t shaped bracket in bolted under the seat to sturdy it. Most good radio (mil surplus) dealers can help you with what you will need, the installation kits are about impossible to find though, but most of the needed parts are avial here an there.
68 M-715 MVPA# 2710
Very good information. One should keep in mind that the M42 trucks were phased out about the same time the 100 amp setup was being installed on M37s as per the TM update. They did use M37s with multiple radio setups requiring the higher amp setup but for some reason some people equate the 100 amp system on a truck as being a remanent of a M42 set up.
The map table in the photo is a repro made by a dealer some years back. I made my own as I was able to find the same hardware at the local TrueValue store. Mine looks exactly the same except I used drilled two holes in the upper tube instead of a long slot for adjusting the legnth of the legs. I drilled out for the wingnuts in two places so I can still use the table on the back of the truck like in the TM photos. The legs just do not have the sliding up and down funtion like the original table but two fixed positions instead. It was about $250 cheaper than the repro when when finished. I also made mine a couple inches smaller on each side at the original size table top is pretty big and makes entering the truck a challenge.
I will dig mine out of my M42 parts pile and take some pictures of it. Look for a post with photos later on...
Rusty S.
I don't care for the lack of security with the bench-mounted set so I opted for the PRC-77 pack radio which can be carried in and out of the M as needed. I know, not "correct" for those who are going for 100-point show quality but I'd rather not lug the big AN-VRC 524 radio back and forth, and worry about who might carry it off.
Just my 2 cents,
Just my 2 cents,
This is a link to a thread from January 08 on the subject of M37 radio setups I had bookmarked.
viewtopic.php?t=289&highlight=radios
