Civilian vs Military 230
chicklin
Post by chicklin »
What are the differences between the civvy and military 230's? Are there any? I know the distributor is different, but outside of the accessories, is the core engine different? Thanks!
refit1701
Post by refit1701 »
Oil pump drive to distributor is different.
Oil fill tube is press in on civie and bolt on with Military engines.
That's all I can think of at the moment.
-John
Member of Dixie Division MVC
1953 USAF M37 wow, restored
1953 USMC M37 w/w -in storage
1967 M116A1 Pioneer Trailer
S-89 Comm box
Nickathome
Engines
Post by Nickathome »
Can't comment on the civy engine but my military industrial engine has a few differences from the stock military engine. One being the pressed in dip stick tube, the other being the lobe on the cam that drives the fuel pump is in a rearward location almost too close to the down tube of the exhaust. My engine has two ports with the front one closed off with a cap, no lobe on the cam in that location. weird.
W_A_Watson_II
Post by W_A_Watson_II »
OK, question. the distributor on the left came out of my M's 230, and the one on the right is out of my PW's 230. I didn't see what I expected to see on the M's distributor tang, as I see no offset? Am I missing something?
Will
1946 Dodge Power Wagon
My 1953 Dodge M37 WEB Site
Nickathome
Tang
Looking straight down at the tang(as in holding the dist upside down) it should not dissect the shaft through the center but should be offset. Supposedly a civy dist will have this tang dead center in the shaft (think of it cutting through the center like the slot in a slotted head screw does). Yours from your M should be offset as it appears identical to mine and the tang on mine is offset.
The military ones are all off center tangs; unless the shaft has been replaced with a civilian shaft, which will fit. This is most often done when the oil pump gets replaced with a parts house civilian model (Melling #M37) which has the centered slot. You would be surprised how often this actually happens because people assume finding the correct mil spec parts is impossible. Many mechanics will trash the military distributor ASAP, they simply don't know what to do with it, it looks wierd.
W_A_Watson_II
OK, took a look, and I now see the slight offset. The tang is also thinner.
An interesting thing though, I looked at my PW 12 volt distributor, and noticed it's a sealed unit, no way to access any points or condenser. anyone with details on what is, or how it works, a "Chrysler Corporation Solar Spark Ignition"? Part Number 930366, Auto-Lite # AD-4039-1
Will
I am a Christian and believe in the one true God.
I believe marriage is between a Man and a Woman.
I believe in life, and oppose abortion.
I support the 2nd Amendment.
I believe in border security and legal immigration.
I support the Men and Women who defend the people of this nation.
I am a Conservative who believes in the Republic, not socialism.
Am I a threat to Homeland Security, or Am I Homeland Security?
I AM Homeland Security
Will
Never saw one that was sealed. That wouldn't be possible as we all know points & condenser have to be renewed periodically. Are you looking at the plastic cover that is right under the rotor? Some have that & it simply slips off after removing the rotor, or there could have been some type of electronic assy installed, seen that a time or 2.
W_A_Watson_II
Well here it is. Actually the metal cover is indeed removable, it's a snug fit, but very clean on the inside.
Will
W_A_Watson_II wrote:Well here it is. Actually the metal cover is indeed removable, it's a snug fit, but very clean on the inside.
That's what I was speaking of, it slips upward after rotor removal, many civilian ones are like this. This type is very popular & typical with older gas powered farm & industrial equipment.
