Rear tail light recommendation
I have a stock M37 in 24V what upgrades if any would you recommend for the rear brake lights and turn signals? Thanks
If you want military style I would go with the larger composite lights, lots safer, you can also get them in LED from Grote or Trucklite, or find some of the older bulb type, they come up on ebay regularly. you could also use a commercial light and change the bulb to a double filiment 24V lamp #1662, it is a direct replacement for the 12V 1157
I went with Gammagoat taillights, even though they don't have the "cat eyes" for blackout drive because I need the additional brilliance of the lights that the stock lights don't provide. I also plan on using a detachable amber "whoopee light" when on the road.
