transmission interchangeability question
Posted: Fri Nov 21, 2008 10:54 am
by monkeymissile
Folks,
I am trying to find out if an NP420 from a '66 PW will work in a 1953 M-series. Thanks.
Re: transmission interchangeability question
Posted: Fri Nov 21, 2008 2:25 pm
monkeymissile wrote:Folks,
No
Posted: Fri Nov 21, 2008 7:14 pm
by k8icu
Ok why not? Or better yet what is needed to make it work? An adapter? Is the spline different? The shaft too long?
Posted: Fri Nov 21, 2008 8:40 pm
k8icu wrote:Ok why not? Or better yet what is needed to make it work? An adapter? Is the spline different? The shaft too long?
Different mounting hole pattern. It can be adapted if you drill & tap the bell housing to match.
Posted: Sat Nov 22, 2008 8:48 am
by monkeymissile
thank you!
