Folks,
I am trying to find out if an NP420 from a '66 PW will work in a 1953 M-series. Thanks.
transmission interchangeability question
monkeymissile
- SSGT
1953 Dodge M43
Fail often to succeed sooner
Re: transmission interchangeability question
Nomonkeymissile wrote:Folks,
Different mounting hole pattern. It can be adapted if you drill & tap the bell housing to match.k8icu wrote:Ok why not? Or better yet what is needed to make it work? An adapter? Is the spline different? The shaft too long?
monkeymissile
- SSGT
