Over the last two weeks I have been buttoning up my rebuild. Last week I go to fire her up and BAM-BAM. One out the exhaust and one backfire out the carb. Ok, obviously timing.I had recently installed the oil pump and figured that would be the first place to start. I pull the cap and with one at TDC the rotor is at six. I do a 180 on the pump timing gear and try her again. She catches, runs for about 30 seconds and I shut her down as I did not have coolant in her. I wanted to make sure it was going to run before I bolted the radiator and filled it up with coolant.
Cool I thought. So I bolt in the radiator and fill it up. Now today I go to start it and nothing. It acts like it wants to catch but just won't. Like a timing issue. Ok, so maybe I am a tooth off on the pump? It still should do something, it ran last week. So I decide to check the mechanical timing from scratch. I run #1 to TDC both valves closed. I pull the oil pump. I re-set everything by the book. I had to turn the pump 180 again??? So now with number one at TDC, both valves closed, which should be the firing position?, the rotor is now at 6 o'clock? This isn't right, is it? If I run number 6 up to TDC, both valves closed, the rotor is at 1 o'clock. This is how it was originally when I got the backfires
So I then start to think, maybe the crank to cam timing is off. Despite me checking it twice before assy. At this point I am going nuts and believe anything is possible. So I spend an hour draining the radiator, yanking the engine mount so I could pull the timing cover. Marks are dead on. I have re-checked the valves. Compression on my fresh bores is @100lbs. It has not run long enough for the rings to seat. One way backfires, the other it struggles to start.
With the distributor zero degrees vertical to the block, should the rotor be pointing at the vent fitting for seven o'clock or closer to the center screw hole for the cap? I cant tell seven o'clock from 8??
I am about ready to send it on a pallet to Charles. Am I missing the obvious??Help!
l
