My low beam gave out on the truck and I pulled out the bulb and it is a Wagner 4800 it onyl lasted about 10 months. I look at my replacement parts sheet and it recommends a Wagner 4860, does anyone know the difference in the two? I am running a 24V system in the truck.
Head light question
Re: Head light question
The 4860 is the military version with attached wire leads. The 4800 is the civilian style with the standard 3 prong set up that plugs into a socket. Both are 24 volt & either will work just fine. The 4800 can be had from your local parts house.dman wrote:My low beam gave out on the truck and I pulled out the bulb and it is a Wagner 4800 it onyl lasted about 10 months. I look at my replacement parts sheet and it recommends a Wagner 4860, does anyone know the difference in the two? I am running a 24V system in the truck.
