These chains are brand new, never been used and are nine feet long with a grab hook on one end. Use them to tie down and secure you backhoe, tractor, truck, generator or other equipment when hauling to a jobsite, or when hauling materials or equipment accross the country. These chains are tough.
Grab hook is angled so that the chain will pull straight instead of being "bent" when hooking back on itself or for when you hook onto an attachment point on your trailer. It's stronger than using a regular straight grab hook.
Specifications: NSN 1670-00-778-4079; Design Rating 35,350lbs.; Breaking Strength 25,000lbs.; Size 1/2"; Length 9' Nominal Chain, Weight 22lbs.; Meet Requirements of MIL-DTL-6458E.
Each chain is $25. I can put them in the large flat rate USPS box and send them out for $14 a chain... They can also be delivered/picked up at a show that I (or somebody near me) is attending.
