What is THIS?????
nivek
What is THIS?????
Post by nivek »
Replacing a known torched rear diff on Old Blue, placing the *new* diff into place, this tool steel thingamambob fell out.
I have no clue.
Before I bench this differential, I would LOVE to know what this object is and where it goes, and what the hell it does.
Thanks in advance!!!!
kevinL
'52 M-37 "Rusty Red" parted
TOM R
Post by TOM R »
just a guess but something to do with the spider gears
1945 t24/m29 weasel
1946 cj2a ww2 style
1954 m37
mvpa 31698
nra lifer
nivek
Pic of the diff in the Book.
Post by nivek »
Is this the Drive Gear Thrust Screw Pad?
Hate to tear apart a diff that doesn't need it just to discover some smart ass tossed this iron in.
kL
Tom P
Post by Tom P »
Yes that is the Thrust pad.
It will need to be put back in and adj.
Now for your next surprise,
The hex nut on the adj. screw is supposed to be tack welded.
Dumb move,but that's what they do.
If it is you will need to carefully cut the weld or find a new screw and nut.
Some MV suppliers have them NOS.
TGP
"47" WDX WW
"52" M37 WW
"54" Willys M38A1
"65" M35A1 WW
To Many Others
nivek
Thnx Tom P.. Suprisingly I have a box of those..
Post by nivek »
Won in a "take it all" auction.
Brand new "punkin' pusher bolts" as my buddy the antique, err, old farm equipment fixer calls them. (He is OLD compared to my spring youth of not_yet_fifty!)
Looks like I'll tear this good diff down and see what is inside, drop the spider and brass set in while I'm fooling around in it's guts..
Damn glad it choose to fall out NOW, rather than start clanking around well after chassis is rolling around!!!
Appreciate the help Gents. Makes hanging around Robi's that much more pleasurable.
kevinL
It is the thrust pad, BUT the fact that it just dropped out spells bad news. If it had been installed & adjusted correctly, there is NO WAY it could have just dropped out. 1 of 2 things would have taken place, the adjustment screw jamb nut could have backed off, not likely as they are most often welded. BTW you can easily salvage & reuse the adjustment screw & jamb nut even though it has been welded, we have reused these countless times. 2nd possibility, incorrectly adjusted ring gear carrier or bad carrier bearing that has let the carrier shift out of its correct position. I'd bet something is going on along these lines, the pad doesn't just fall out. Correct adjustment is .006" - .008" between the pad & the back side of the ring gear, hardly enough slack that it can fall off the pin.
